Amiko A5 Settings by Morpheus883
This Section Using About Download Software Vu Solo Receivers .....
sugar
Turkey
Post by sugar »
Amiko A5/A6 Settings 27th November 2024 © by Morpheus883:
Settings for Images based on Android FW's:
Statistics:
# Clarke Belt covered: 47.5°W - 76.5°E
# Satellites: 88 (Ku Band TP + DTV Freq. Lists)
# Services: 16.508
# Ordered Provider Lists: 55
It's a full channel list for Amiko A5/A4/A6 Android FW's...
- New Extended TP Table (full scan required)
- Added Parental Control Flags (The default password is ‘0000’)
Instructions: FTP/Overwrite the file prog.db into /data/data/com.linkdroid.home/databases folder.
Since it's the first channel list available for these decoders, any feedback, suggestion, integration, correction and support (and a simple "Thanks") is very important and greatly appreciated ;)
=== Compiled with Morpheus883's scripts ===
======= © by Morpheus883, 2024 =======
A5_Morph883_Motor_271124.zip (1.04MB)
https://www.sendspace.com/file/f2jxmf
sugar
Turkey
Re: Amiko A5 Settings by Morpheus883
#2
Post by sugar »
Amiko A5/A6 Settings 4th December 2024 © by Morpheus883:
Statistics:
# Services: 16.521
A5_Morph883_Motor_041224.zip (1.04MB)
https://www.sendspace.com/file/0c1ps3
sugar
Turkey
#3
Post by sugar »
Amiko A5/A6 Settings 10th December 2024 © by Morpheus883:
Statistics:
# Services: 16.499
A5_Morph883_Motor_101224.zip (1.04MB)
https://www.sendspace.com/file/iiygw0
sugar
Turkey
#4
Post by sugar »
Amiko A5/A6 Settings 18th December 2024 © by Morpheus883:
Statistics:
# Services: 16.551
A5_Morph883_Motor_181224.zip
(1.05 MiB) Downloaded 4 times
sugar
Turkey
#5
Post by sugar »
Amiko A5/A6 Settings 24th January 2025 © by Morpheus883:
Statistics:
# Services: 16.296
======= © by Morpheus883, 2025 =======
A5_Morph883_Motor_240125.zip
(1.03 MiB) Downloaded 4 times
Return to “Vu Solo Receivers”
