Smart Launcher 6 v6.5 build 001 [Pro] [Mod Extra]
Requirements: 7.0+
Overview: Smart launcher provides a new Android experience focused on efficiency and customization.
A new simple home screen showing what matters. All your apps sorted into categories. Everything you need to perform your daily tasks faster and easier.
Best Android Launcher 2020 - Android Central
Best Android Launcher 2020 for customization - Tom's Guide
Best launcher Android app for efficiency 2020 - Android Headlines
Top 10 Launchers - Android Authority, Tech Radar
Playstore Best App 2015 - Google
• Automatic app sorting
Apps are automatically sorted in categories, you won't have to waste time organizing your icons anymore! The advantages of the automatic app sorting have been recognized also by Apple which introduced it in their App Library in iOS 14.
• Ambient theme
Smart Launcher automatically changes the theme colors to match your wallpaper.
• Designed to be used with one hand
We moved the items you need to interact the most in the bottom part of the screen where they are easier to reach.
• Customization
Smart Launcher is completely customizable. You can now modify every single color of smart launcher theme unlocking infinite possibilities of color combination. Change fonts on the home screen choosing among thousands of fonts from Google Fonts.
• Smart search
The Smart Launcher search bar allows to quickly find contacts and apps or to perform actions like searching on the web, adding a contact or performing a calculation.
• Adaptive icons
The icon format introduced with Android 8.0 Oreo is fully supported and available for any Android device! Adaptive icons means not only customizable shapes but also beautiful and bigger icons!
• Gestures and hotkeys
Both gestures and hotkeys are supported and configurable. You can turn off the screen with a double tap or show the notification panel with a swipe.
• Built-in clock widget with weather
The built-in widget has been redesigned to show info like alarm, next event and weather.
• On screen notifications
Smart Launcher will now show you which apps have active notifications without requiring to download an external plugin. This makes the feature more stable and reliable.
• Ultra immersive mode
You can now hide the navigation bar in the launcher to maximize the screen space.
• Protect your apps
You can hide the apps you want and if you want to keep them secret, you can protect them with a PIN.
• Wallpaper selection
Smart Launcher includes a very efficient wallpaper picker that allows you choose between many sources of pictures. You can also backup your wallpaper before to try a new one!
- Option to automatically hide the music widget when no player is running
- Ability to hide shortcuts and settings in search results
- Web suggestions added for Bing, Brave, DuckDuckGo, Ecosia, Qwant, StartPage, and Yahoo
- Option to disable vibration when performing a gesture
- Export your feeds as an OMPL file
- Fix: you can now add 2 or more feeds from the same website
Mod Info:
Pro / Paid features unlocked;
Disabled / Removed unwanted Permissions + Receivers + Providers + Services;
Optimized and zipaligned graphics and cleaned resources for fast load;
Ads Permissions / Services / Providers removed from AndroidManifest;
Ads links removed and invokes methods nullified;
Ads layouts visibility disabled;
Google Play Store install package check disabled;
Debug code removed;
Remove default .source tags name of the corresponding java files;
Analytics / Crashlytics / Firebase disabled;
No active trackers or advertisements;
AOSP compatible;
Languages: Full Multi Languages;
CPUs: universal architecture;
Screen DPIs: 120dpi, 160dpi, 240dpi, 320dpi, 480dpi, 640dpi;
Original package signature changed;
Release by Balatan.
https://katfile.com/1f0bb6ejahc7
- adrianoluis
- Dev
- Has thanked: 5 times
- Been thanked: 34 times
