CiefpSettingsDownloader
This Section Using About Download Software Vu Solo Receivers .....
sugar
Turkey
Post by sugar »
CiefpSettingsDownloader v1.1 py3
Download and install Ciefp settings from GitHub
Plugin je namejen za instalaciju više verzija mojih listi sa Github
Pokrenete plugina izaberete želejenu verziju sačekate par sekundi
ako izađe poruka :
Reload successful! New settings are now active. .::ciefpsettings::.
Instalacija je završena i nije potreabn restart
The plugin is intended for installing multiple versions of my settings from Github
Start the plugin, select the desired version and wait a few seconds
if the message appears:
The installation is complete and no restart is required
instalacija se vrši preko telneta sa wget komandom
installation is done via telnet with the wget command
ciefp-E2-1sat-19E
ciefp-E2-2satA-19E-13E
ciefp-E2-2satB-19E-16E
ciefp-E2-3satA-9E-10E-13E
ciefp-E2-3satB-19E-16E-13E
ciefp-E2-4satA-28E-19E-13E-30W
ciefp-E2-4satB-19E-16E-13E-0.8W
ciefp-E2-5sat-19E-16E-13E-1.9E-0.8W
ciefp-E2-6sat-23E-19E-16E-13E-1.9E-0.8W
ciefp-E2-7sat-23E-19E-16E-13E-4.8E-1.9E-0.8W
ciefp-E2-8sat-28E-23E-19E-16E-13E-4.8E-1.9E-0.8W
ciefp-E2-9sat-28E-23E-19E-16E-13E-9E-1.9E-0.8W-5W
ciefp-E2-10sat-39E-28E-23E-19E-16E-13E-9E-4.8E-1.9E-0.8W
ciefp-E2-13sat-42E-39E-28E-23E-19E-16E-13E-9E-7E-4.8E-1.9E-0.8w-5w
ciefp-E2-16sat-42E-39E-28E-26E-23E-19E-16E-13E-10E-9E-7E-4.8E-1.9E-0.8w-4W-5w
ciefp-E2-18sat-42E-39E-36E-33E-28E-26E-23E-19E-16E-13E-10E-9E-7E-4.8E-1.9E-0.8w-4W-5w
ciefp-E2-75E-34W
CiefpSettingsDownloader.rar
(778 Bytes) Downloaded 8 times
Return to “Vu Solo Receivers”
