[E² Plugin] X Klass - Xtream Codes IPTV Player
This Section Related About IPTV apps Downlaod Here and Share....Note Only Share Enagma2 Plugins...
XKlass - Official Release - The Final Frontier.
V 1.19 - 12/11/2024
VOD - IMDB plugin - name and prefix stripping for better results
German translation update
enigma2-plugin-extensions-xklass_1.19.20241112_all.ipk
https://uploadrar.com/druvcwirrh54
enigma2-plugin-extensions-xklass_1.19.20241112_all.deb
https://uploadrar.com/7cxwlwo8tvnc
ocean777
Been thanked: 5 times
Andorra
Re: [E² Plugin] X Klass - Xtream Codes IPTV Player
#2
Post by ocean777 »
V 1.20 - 13/11/2024
#3
V 1.20 - 13/11/2024
Fixed lists resetting when going off screen unless you change the playlist.
Fixed 0.0 rating value crashing the vod data page
Fixed the incorrect playlist showing on the startmenu if you had dead playlists in your files.
enigma2-plugin-extensions-xklass_1.20_2024113_all.ipk
https://uploadrar.com/lelo2yc84zof
enigma2-plugin-extensions-xklass_1.20_2024113_all.deb
https://uploadrar.com/r1a0at11jr8z
kingsman
New Member
New Member
Has thanked: 2 times
Been thanked: 2 times
France
#4
Post by kingsman »
X Klass v1.23
Tweaks to the list indexes on back button.
Code: Select all
https://nitroflare.com/view/420FA52AB2F398B/X_Klass_1.23.zip
Vu+ Duo4k
Return to “Enigma 2 Plugin For Iptv”
