E2iPlayer
This Section Related About IPTV apps Downlaod Here and Share....Note Only Share Enagma2 Plugins...
Warder
Has thanked: 2 times
Been thanked: 17 times
Slovakia
E2iPlayer
Post by Warder »
E2iPlayer
Code: Select all
wget -qO- --no-check-certificate https://mohamed_os.gitlab.io/e2iplayer/online-setup | bash
OR:
Code: Select all
curl -LJso- https://mohamed_os.gitlab.io/e2iplayer/online-setup | bash
Nosce te ipsum.
ocean777
Been thanked: 5 times
Andorra
Re: E2iPlayer
#2
Post by ocean777 »
Update
15/11/2024
Stop Support Python 2
Thanks MOHAMED OS
Code: Select all
    OR:
ocean777
Andorra
Re: E2iPlayer
#3
Post by ocean777 »
Update
17/11/2024
Thanks MOHAMED OS
Code: Select all
    OR:
ocean777
Andorra
Re: E2iPlayer
#4
Post by ocean777 »
13/12/2024
Thanks MOHAMED OS
Code: Select all
    OR:
Return to “Enigma 2 Plugin For Iptv”
