MX Player Pro
MX Player Pro
MX Player Pro v1.15.5 [Patched] [AC3] [DTS] [Ultra Mod Lite]
Requirements: 4.2+
Overview: Powerful video player with advanced hardware acceleration and subtitle support.
a) HARDWARE ACCELERATION - Hardware acceleration can be applied to more videos with the help of new HW+ decoder.
b) MULTI-CORE DECODING - MX Player is the first Android video player which supports multi-core decoding. Test result proved that dual-core device's performance is up to 70% better than single-core devices.
c) PINCH TO ZOOM, ZOOM AND PAN - Easily zoom in and out by pinching and swiping across the screen. Zoom and Pan is also available by option.
d) SUBTITLE GESTURES - Scroll forward/backward to move to next/previous text, Up/down to move text up and down, Zoom in/out to change text size.
e) KIDS LOCK - Keep your kids entertained without having to worry that they can make calls or touch other apps. (plugin required)
Subtitle formats:
- DVD, DVB, SSA/ASS subtitle tracks.
- SubStation Alpha(.ssa/.ass) with full styling.
- SAMI(.smi) with Ruby tag support.
- SubRip(.srt)
- MicroDVD(.sub)
- VobSub(.sub/.idx)
- SubViewer2.0(.sub)
- MPL2(.mpl)
- TMPlayer(.txt)
- Teletext
- PJS(.pjs)
- WebVTT(.vtt)
About "Draw over other apps" permission: This permission is required to block system buttons when input blocking is activated on the playback screen.
About "Pair with Bluetooth devices" permission: This permission is required to improve AV sync when Bluetooth headset is connected.
About "Disable screen lock" permission: This permission is required to remove screen lock temporarily when Kids lock mode is used. Nevertheless, secure screen lock will not be disabled.
About "Control vibration", "Prevent device from sleeping" permissions: These permissions are required for media playback on some devices.
* Introducing MX Share, a P2P based file-sharing. Now share your video without the internet! (This would require some additional permissions. Read the app description to know more.)
* Now features a custom Picture-in-Picture mode, which is compatible with all Android versions. Oh yes, It is also resizable :)
Other noticeable improvements:
* You can now use system brightness controls while using PIP.
* Floating button and last played marking are now properly updated when using Background Play.
Mod Info:
Optimized graphics and cleaned resources for fast load < improved result (12.1 MB total apk size);
Disabled / Removed unwanted Permissions + Receivers and Services;
Analytics / Crashlytics disabled;
Changed activation icon in menu/about;
Removed startup Google Consent;
Support for armeabi-v7a and arm64-v8a devices only;
Disable Popup Rate dialog;
Encrypted all resources;
Languages: En, Ru.
https://rapidgator.net/file/b1b08d0fa80 ... 0a12a0ca5d
