BackUp Maker Professional 8.310 Multilingual Fast Links | 19.1 Mb
Viruses, user errors and computer crashes put you at risk to lose important data at any time. Therefore, it is crucial to secure your files regularly so that in cases of emergency, your computer data is still accessible.
BackUp Maker automatically stores your files and at the same time offers an intuitive functionality. Select your data, optionally set automatization for scheduled backups, select its destination and within an instant, your valuable documents are transferred in zip format to a hard drive, USB flash drive or directly to the Cloud as scheduled or according to circumstances.
To ensure that your sensitive data remains secure at all times, BackUp Maker provides a highly secured encryption of up to 256 bits (AES). It also enables you to transfer protected backups to a webserver through an FTP/FTPS upload.
Security Features: You can limitlessly secure information using BackUp Maker. Back-up only new and changed files; generate as many backups as needed; split the backup across multiple data storage devices and carry out random operations before or after backups!
Supported Operating Systems:
Windows 11
Windows 10 (32-bit & 64-bit)
Windows 8.1 (32-bit & 64-bit)
Windows 8 (32-bit & 64-bit)
Windows 7 (32-bit & 64-bit)
Windows Vista (32-bit & 64-bit)
Windows XP (32-bit & 64-bit)
Windows Server 2016/2019 (32-bit & 64-bit)
Windows Server 2012 (32-bit & 64-bit)
Windows Server 2008 (32-bit & 64-bit)
Windows Server 2003 (32-bit & 64-bit)
https://rapidgator.net/file/2dc5fd8d834 ... l.rar.html
