Hallo,
Bin neu hier, bin sozusagen zufällig drüber gestolbert
Hier die neuste MCS Version "MultiCS N4 r87"
benutze ich selber seit her so gut wie keine Freezer mehr mit der "098D"
MultiCS N4 r87
- Tester1000
- New Member
- Has thanked: 1 time
- Been thanked: 1 time
MultiCS N4 r87
- Attachments
- R87update4102024.part2.rar
- (79.53 KiB) Downloaded 6 times
- R87update4102024.part1.rar
- (250 KiB) Downloaded 6 times
Re: MultiCS N4 r87
MultiCS N4 r87
It is an attempt to solve channel issues (fake keys), and I believe I have reached a satisfactory result in this version.
README.txt
MultiCS N4 r87 - Release Notes
Updates and Fixes:
Fake Keys Issue Resolved: The problem with fake keys in M*O and N*S has been addressed and fixed in this release.
Requirements:
Reliable Local Line: Ensure you have at least one line from a trusted local source; otherwise, the program may not function correctly.
Good Server: A server with at least medium to high specifications is recommended for optimal performance.
Reminder: Please refer to the first requirement to avoid any issues with the program’s performance.
Additional Fixes:
Fake Cache Issue Resolved: The issue with fake cache has also been resolved in this version.
Real Local Cache Preferred: It is recommended to have a real local cache from a trusted source for better performance.
Performance Improvements:
Faster Performance: The program is now faster than before, ensuring smoother operation.
Now Free: This version is now available for free.
Version Information:
Version upgraded from r82: This version is an enhanced and improved version of the original r82 source, with additional features and fixes for better reliability and performance.
Download mcs R87: https://we.tl/t-E0fiORxHR1
Atention: You must have Ubuntu 20 and 22
How install:
sudo apt-get update
sudo apt-get install libmysqlclient-dev
How fix
- error while loading shared libraries: libmysqlclient.so.20: cannot open shared object file: No such file or directory
- wget https://mirror.iranserver.com/ubunt...s ... _amd64.deb
- sudo dpkg -i libmysqlclient20_5.7.35-0ubuntu0.18.04.1_amd64.deb
- sudo apt --fix-broken install
Thank you!
README.txt
Updates and Fixes:
Requirements:
Additional Fixes:
How install:
sudo apt-get update
How fix
Thank you!
