NIUBI Partition Editor 10.0.9 Multilingual
NIUBI Partition Editor 10.0.9 Multilingual Fast Links | 11.5 Mb
If you provide IT technical service to your clients and need a powerful disk partition management toolkit, NIUBI Partition Editor Technician Edition is the best choice. This partition manager software is compatible with Windows Server 2016/2012/2008/2003 and Windows 10/8/7/Vista/XP. Local/removable hard disk, VMware, Hyper-V and all types of hardware RAID are all supported.
Better than other utilities, NIUBI Partition Editor integrated unique Roll-Back data protection technology, which is able to roll back the computer to the status before resizing automatically if any hardware issue occurred, so you dont need to worry about data safety. Furthermore, the built-in unique file-moving algorithm helps resize partition 30% 300% faster than other tools. Time is important to you and your customer!
NIUBI Partition Editor Technician Edition is the best cost-effective option for you to provide charged technical services for multiple companies and individuals. One license code can be registered on unlimited desktops, workstations and servers regardless of network size or architecture.
Operating System:Windows 10/8/7/ista/XP and Server 2016/2012/2008/2003
https://rapidgator.net/file/45be8d38888 ... l.rar.html
