Requirements: 9+
Overview: Tapet ® ("Wallpaper") is a first of its kind app that automatically generates high-quality backgrounds. You can either select a random wallpaper or let the app generate one for you hourly or daily.
Features:
* Wallpapers are created according to your device's screen resolution - making them the highest possible quality.
* No images are being downloaded from the internet. Everything is rapidly generated on your device.
* Images fit your screen perfectly and even create a beautiful parallax effect, making the wallpaper even more pleasant.
* Stay tuned for new exciting patterns!
* You can set the app to surprise you with a new wallpaper hourly or daily. You will most likely never see the same wallpaper twice.
★ Premium / Paid features Unlocked
★ .source attributes of the corresponding java files removed
★ All Debug code removed
➡ CPU architectures: arm64-v8a, armeabi-v7a
➡ Screen DPIs: 160dpi, 240dpi, 320dpi, 480dpi, 640dpi
Introducing Styles mode: A simpler approach to Tapet's greatness!
https://katfile.com/kwjs5dnjuy65/Tapet_ ... m.apk.html
