Football Live TV HD
Football Live TV HD
Football Live TV HD [Football Live HD] v4.0 [Nov 22,2024] [Adapt Mod]
Requirements: Limited 5.0+
Overview: This is a simple to use app that allows you to view all live football matches.
Live Football TV HD is a unique TV app designed to achieve the best user experience and offer high quality video streaming for users.
If you are not in front of tv and don’t want to miss live Football match updates then this live football tv app is a gift for you to stay updated with live football matches anywhere. This is a simple to use app that allows you to view all live football matches. Football-soccer matches are streamed live in HD quality for high-speed Internet users and in low quality for 3G users.
Whether you're on the go or relaxing at home, our app provides a gateway to the world of football, allowing you to witness the drama unfold in real time. Enjoy this live football tv app and share with friends and family.
VERSION 4.0 Newest! Nov 22, 2024
-No changelog
Tested With Clean Install Only On 60+ Diff TV Devices, 30+ Phones 6,7,8,9,10,11,12,13 & 11 Diff Tablets
Mouse Needed For TV Devices
Thank You To All My Testers
All Mods Tested On A13
If Fails To Load Stream There Is No Live Game!
It Will Say Live When Nothing Is Live..........
Android Phone Mouse For TV Devices Included In Downloads
*Recommend This Over Using Mouse Toggle If It Works For You
How To Use Mouse From Phone To TV Devices:
*Set Orientation Must Be Disabled On TV Devices
Enter IP Address Of TV Device Into App On Phone
Check Popup Box On TV Device & Follow Prompts
Now Have A Working Android Phone Mouse For TV Devices
*Works On Gen3/Lite Firesticks
BOTH ANDROID TV & GOOGLE TV DEVICES CAN NOW USE NEW MATVT MOUSE TOGGLE
How To Setup MATVT Mouse Toggle For AndroidTV/GoogleTV Properly:
Istall MATVT Mouse Toggle 1.0.7 DO NOT OPEN!
Open Settings
Device Preferences Or System
Accessibility
Mouse Toggle Service Enable
Go Back To Settings Then Apps
Special App Access
Display Over Other Apps
Turn On MATVT-Mouse for Android TV Toggle
Go Back To Settings
Remotes & Accessories/Setup Remote Buttons
All 3 Must Be Set To (CEC):
Volume Control Auto(CEC)
Power Button TV(CEC)
Input Button(CEC)
Go Back To Apps & Open MATVT-Mouse for Android TV Toggle
Both Permissions & Services Will Be Lit Up Green
Scroll Down & Select DETECT Button
Hold Down Mute Button For 3 Sec
An Arrow Cursor Will Show Then Select YES
You May Get Allow USB Debugging Popup
Check USB Debugging Box & OK
You Can Change Mouse Icon Type/Size
You Can Change Scroll Speed
How To Use MATVT Mouse Toggle:
Hold Down Mute Button 1 Long Sec
Cursor Will Appear To Select/Play/Open Menu/Open Search
Tap Mute Button To Put In Scroll Mode
Tap Mute Button Again To Put Back In Cursor Mode
Hold Down Mute Button 2-3 Sec To Disable Mouse To Type In Keyboard Or To Exit App
Adaptive Mod Info By Spydog:
Arm7/arm64-v8a
Location removed
Ads patched/disabled
Ad view folders removed
Apphub services removed
Receive cloud data removed
Foreground services untouched
Access all adservices removed
Advertising ID Permission removed
Read phone status/identity removed
Audience network disabled/dex removed
Size increased due to Vpn Block + proper banner/logo
All Start.io ad services/ad activity is fully disabled
*Removing the Start.io popup window breaks the app on mobile devices
>>>Simply disagree 1st time or go back to clear if it doesn't vanish
Arm7 Custom TV Devices Without VPN Block
https://uploadrar.com/aq41cj6ftbey
