Terraria
Terraria
Terraria v1.4.4.9.6 [Paid] [Patched] [Root]
Requirements: 6.0+
Overview: DIG! FIGHT! EXPLORE! BUILD! Join the community of millions of Terrarians!
TERRARIA MOBILE REBUILT FROM THE GROUND UP – NEW AND IMPROVED 1.4.4 UPDATE INCLUDING LABOR OF LOVE CONTENT!
"This is the full version of Terraria, built from the ground up... If you loved it on PC or consoles, you’ll love it here.” - Slide To Play
The very world is at your fingertips as you fight for survival, fortune, and glory. Delve deep into cavernous expanses, seek out ever-greater foes to test your mettle in combat, or construct your own city - In the World of Terraria, the choice is yours!
We recommend at least 2GB of RAM and a device from 2014 or newer. We support devices running Android 5.0 with 1GB of RAM and compatible graphics, but these devices may experience reduced performance.
• MULTIPLAYER – Play with up to 7 friends on Local Wifi or Online via device-device Wifi hosted games or through the Mobile Terraria Dedicated Server for PC (available for free on Terraria.org)
• TERRARIA REIMAGINED FOR MOBILE – Fully customizable controls and User Interface provide a level of polish and capability not previously possible!
• Gamepad support – including fully-remappable buttons - Play with your Bluetooth connected gamepad where supported.
• Full array of World sizes – Small/Medium/Large...the same size as on Terraria for PC! Now includes random world name generator and the ability to use World Seeds (including some hidden easter egg worlds)
• Over 400 enemies to combat, defeat, and plunder for loot
• Over 20 Biomes and Mini-Biomes to explore, both above and underground – from lush forests to barren deserts to dungeons, the underworld, and even the terrifying Corruption await!
• Updated crafting with multiple added item options
• Over 20 NPCs to discover, each providing their own benefits and unique style
• In-depth building options that are easy to learn but allow for amazing feats of architecture in the hands of a master.
• And much, much more!
In short, every pixel of Terraria has been reimagined and hand crafted for the BEST possible mobile experience!
Follow us on Twitter @Terraria_Logic and @505_Games
Installation instructions:
Root-
⁍ Signature verification has to be disabled to perform the installation, this can be done with Lucky Patcher.
⁍ Detailed instructions can be found here
A small update to meet target API level requirements.
arm7+arm64
https://devuploads.com/ma0n71d6vd8v
