Edge Notification - Always On
Edge Notification - Always On v1.41 [Premium]
Requirements: 5.0 and up
Overview: Never miss a notification. Choose your lighting / LED style!
Always On Edge lighting notifications will enable you see all the critical notifications at a glance. You wont miss any important calls, messages, whatsapp, gmail or facebook notifications. Edge lighting is not only a great visual way to be notified about various events, but it also helps to be productive.
What makes the Always On Edge feature so unique:
1. Stand out of the crowd - Beautiful design patterns like pulse, is only available in this app. Customize as per your like.
2. Simple Settings - Out of the box, ready to use. No need to be confused with tons of configurations.
3. No ADs - No annoying popup ads or insecure link clicks.
4. Privacy - App will never send any private notification data outside the phone. Everything stays within your phone.
5. Battery consumption - Minimal battery consumption and doesn't drain your battery.
Application Features:
1. Always On Screen with notification light / LED
2. Customization - Tons of customization options, fonts, clock styles and much more! Choose edge notifications from various smooth animated light effects - Edge lighting, LED notification light, pulse, pulse design, waves and more.
3. Position notifications to left, right or both edges.
4. Speed of animation - fast/slow.
5. Color pattern - solid/gradient.
6. Animation can go on infinite or till specific repeat count for battery saving.
7. Adjust screen brightness as per your requirement.
8. Night mode will switch off the notifications at night and thus will save power.
9. DND mode to avoid getting notifications.
10. Double tap to wake screen on notification.
App will enable lighting edge notifications for all the phones. No need for Always On Display (AOD) feature to be enabled in case you have a Samsung mobile. In addition to lighting edge, you will also be able to customize more designs as per your choice, like dotted pulse design, pulsating circle, waves, stars and more.
Notification light is a very elegant way to let use know about new notifications. Lighting will be bright during initial phase and gradually dim based on selected app brightness to save battery.
NOTE: Default app setting will stop the edge lighting animation after 10 repetition, but you will continue to see the static edge with color notifications. This is done for battery saving as any sort of animation causes more battery usage. You can choose to have animation run infinitely as well. Adjust the settings as per your desire.
Modifications:
✪ Premium features unlocked;
✪ Cleaned all useless files;
✪ Languages: Multi Languages;
✪ All Debug Codes Removed;
✪ CPUs: universal architecture;
➥ Modded By TRUMods
1. LED size and position settings added.
2. EDGE thickness (size) settings added.
3. Stability improvements and fixes.
This app has credit advertisements
https://devuploads.com/7snn1japin60
