Requirements: 5.0+
Overview: A minimalist productivity launcher. One hand-friendly. Zero ads.
Niagara Launcher gives your phone a whole new look and offers a minimalistic experience to help you to form a healthy relationship with your phone. You also get to experience the latest and greatest features of Android 10, including smart replies and dark mode.
Top reasons to use Niagara Launcher:
All apps in a simplified list · You just need to scroll either of the edges on the launcher to get access to all of your apps instantly.
Interact with notifications right on the home screen · Unlike most other launchers, Niagara Launcher gives you essential information about received messages at a glance and directly on your home screen. Swiping on a notification expands it and lets you reply quickly.
Ergonomic efficiency · Niagara Launcher is optimized for one hand usage. Your apps are always within reach and the scrollbar can be used from both sides.
Lightweight & fast · Niagara Launcher is not only lightweight to your phone’s resources, but at just a few megabytes in size, the app takes up very little space. Next to simplicity, fluidity is one of the most important aspects of Niagara Launcher.
Media Player · Music controls automatically show up on your home screen when they're needed, too – anytime you're playing audio from an app.
Theming · Niagara Launcher pulls colors from your wallpaper for a nice thematic effect. Additionally, you can choose between a light or dark theme. Icon packs are supported as well – you can even apply an icon of your choice to each app individually.
Hide unwanted Apps · Hide all pre-installed bloatware, to get a clean and tidy home screen.
❏ Mod info:
◉ Pro Unlocked
◉ No Random Numbers Bug (you might need to clear data if they appear)
◉ Use any other Weather Widget app, Its own weather widget won't work
★ Modded By RBMods
Surveys
With the recent update to the Digital Wellbeing Initiative in v1.12.11, we laid the groundwork for deeper insights. Our next step is to investigate unwanted phone use and phone satisfaction, and we need your input. That’s why we’re launching surveys for participants in the initiative.
We’d appreciate your help – stay tuned for the first new wellbeing feature!
Updated Translations and Added Languages
Added per-app language support for Danish, Farsi, and Slovenian, allowing you to set Niagara Launcher’s language independently of your system settings to these new languages.
Thanks for your continued support! If you encounter any untranslated phrases, we would greatly appreciate your help in submitting translations..
This app has credit advertisements
https://uploadrar.com/0g4oekzxpd63
