[E² Plugin] AJPanel
This Section Using About Download Software Vu Solo Receivers .....
sugar
Turkey
[E² Plugin] AJPanel
Post by sugar »
[v10.2.0 .. 2024-12-01]
- Added Long-PVR (Long-Playlist) key to take a screenshot.
- Added "Delete Reader" (Red Button) to the option "NCam/OSCam Readers" to delete readers.
- Added new options to "OSCam/NCam Status" (in Blue Button) to delete a reader and clean inactive and duplicate readers.
- Improved Download Manager resume process.
- Improved Filter in "Download/Install Packages (from image feeds)" to filter packages per feed.
- Improved Player Bar to forward/rewind while subtitle is running (without showing the bar).
- Improved Player-Bar Buttons.
.. Added PVR/Playlist button to show System Channel Selection.
.. OK-Button will show Channel List (if no active service).
.. Long-Stop and Long-Power buttons will stop current service and zap to the last used service (or show Channel List).
- Improved Stream Relay handling for images with Stream Relay Patch (to handle PIcons/Signal/Data/etc.).
- Fixed changing AJPanel font on DreamOS.
- Fixed "M3U/M3U8 File Browser" to handle unicode files.
- Fixed Playlist timeout problem (when reading categories for some servers).
- Fixed File Manager error when converting .mvi files to jpg/png.
.. Note: this option may not work on some images if the provided ffmpeg does not support mvi.
enigma2-plugin-extensions-ajpanel_v10.2.0_all.deb (415.41KB)
https://www.sendspace.com/file/npxnus
enigma2-plugin-extensions-ajpanel_v10.2.0_all.ipk (504.45KB)
https://www.sendspace.com/file/a6bo1o
Return to “Vu Solo Receivers”
