Internet Speed Meter
Internet Speed Meter v1.6.5-pro [Paid] [Altered] [Purged]
Requirements: Android 9.0 and up
Overview: Internet Speed Meter is a tool which keeps track of your internet speed and usage. It displays your current speed in status bar and how much data you have used in notification pane. This helps you to monitor internet connection anytime while using your device.
Internet Speed Meter displays your internet speed in status bar and shows the amount of data used in notification pane. This helps you to monitor network connection anytime while using your device.
Lite Features
- Real time speed update in status bar and notification.
- Daily traffic usage in notification.
- Separate stats for Mobile network and WiFi network.
- Monitors your traffic data for the last 30 days.
- Battery efficient
Pro Features
Notification Dialog
A notification dialog appears when you tap the notification having
- Graph to monitor last minute internet activity
- Time and usage of current session
- Today's app usage for mobile and wifi
- Realtime speed of running applications
Smarter notifications
Notification appears only when you are connected to internet. You can change priority of notification. You can also hide the notification when connection is idle for specified amount of time.
Themes support
You can manually select the color of UI.
Blue status bar icon
Option to choose between blue or white status bar icon. (only for KitKat and below versions of Android)
Upload and Download Speed
Option to show upload and download speed in separate notifications.
Translations: Arabic, Chinese (Simplified), Chinese (Traditional), Czech, Dutch, French, German, Hebrew, Hungarian, Indonesian, Italian, Japanese, Korean, Kurdish, Persian, Polish, Portuguese (Brazil), Romanian, Russian, Serbian (Latin), Slovakian, Slovenian, Spanish, Turkish, Ukrainian, Vietnamese.
Warning: Do not move this app to SD card. It will stop (Force close) when you remove the card.
- Improved support for Android 12 and 13
- Added back "Hide when disconnected" option
Short Info:
● Universal Package
● LVL Implementaion Removed
● Compression Flags Untouched
● No Additional Component
● No Third Party Patch/Hook/...
● Size: 2.0 MB
● Release by Kirlif'
https://mega4upload.com/lu0fihje9q62
