[E² Skin] oDreamy-FHD
This Section Using About Download Software Vu Solo Receivers .....
sugar
Turkey
Post by sugar »
XDREAMY v 4.4.0
"Experience Enigma2 skin like never before with XDREAMY"
"XDREAMY skin is a new vision, created by Inspiron. Users can fully customize their interface, and change layout, colors, fonts, and screens to suit their preferences. Drawing inspiration from Dreamy and oDreamy skins, XDREAMY incorporates cutting-edge rendering technology, including the efficient PosterX component recoded by Lululla."
Supported Images
Alliance Based Images: (Egami 10.x, OpenATV 6.x, OpenATV 7.x,
OpenSpa 8.x, PurE2 6.x, PurE2 7.x, OpenDroid and OpenBH).
PLi Based Images: (OpenPLi, OpenVIX, OpenHDF, NonSoloSat and Satlodge )
Add support for the Satlodge image (New).
Add an option to change the converter used to pickup cam name (5 options)
Add an option to activate or disable parental rating and IMDB stars (for slow devices)
Add an option to enable/disable the digital subtitles clock and change its position.
Update XDREAMY plugin by Lululla and improve the image/poster handle.
Tweaking and optimizing skin files (now better performance and faster response).
Handel a lot of users' requests
Virtual Keyboard (working on some images, not finished yet).
enigma2-plugin-skins-xDreamy_4.4.0_all.ipk (16.18MB)
https://www.sendspace.com/file/whg102
sugar
Turkey
Re: [E² Skin] oDreamy-FHD
#2
Post by sugar »
XDREAMY v 4.5.0
Supported Images
Option to change the Menu Font Color
Option to change the channels Name Color
Replace some renderers with older ones for better performance
Telnet Code
(Direct Install)
Code: Select all
wget -q "--no-check-certificate" https://raw.githubusercontent.com/Insprion80/Skins/main/xDreamy/installer.sh -O - | /bin/sh
enigma2-plugin-skins-xDreamy_4.5.0_all.ipk (16.16MB)
https://www.sendspace.com/file/o3oqrt
sugar
Turkey
#3
Post by sugar »
XDREAMY v 4.7.0
19.12.2024
Supported Images
Alliance Based Images: (Egami 10.x, OpenATV 6.x, OpenATV 7.x, OpenSpa 8.x, PurE2 6.x, PurE2 7.x, OpenDroid and OpenBH).
PLi Based Images: (OpenPLi, OpenVIX, OpenHDF, NonSoloSat, OpenTR and Satlodge )
Fix the channel list error not being visible after the initial installation with ipk file.
More tweaking and optimizing of skin files is needed (now, better performance and faster response).
XDREAMY PLUGIN: Refresh the interface of XDREAMY Plugin.
XDREAMY PLUGIN: Add an Information Message, including the list of supported images (Press info while opening the plugin).
XDREAMY PLUGIN: Add Skin debugging tools to show skin errors for users (Active only when you have LinuxSat Panel on the system)
telnet code
Code: Select all
enigma2-plugin-skins-xDreamy_4.7.0_all.ipk (16.03MB)
https://www.sendspace.com/file/gb49ol
sugar
Turkey
#4
Post by sugar »
XDREAMY v 4.8.0
Supported Images
PLi Based Images: (OpenPLi, OpenVIX, OpenHDF, NonSoloSat, OpenTR, Cobra and Satlodge )
More tweaking and optimizing of skin files is needed (now, better performance and faster response) Your new feedback is much appreciated
XDREAMY PLUGIN: I added the skin version number to the title to make it more visible.
Finally, the virtual keyboard for pure2 image should be fixed and improved.
Cam Data displayed in Cam Manger (OpenATV), you can change the used Converter from the skin plugin.
Add new screen History Zap Selector.
Remove force restart (killall -9 enigma2) from postinst file (some people believe it is too aggressive),
telnet code
Code: Select all
enigma2-plugin-extensions-foreca_3.3.5_all.rar
(949.09 KiB) Downloaded 4 times
Return to “Vu Solo Receivers”
