1.1.1.1+ WARP: Safer Internet
1.1.1.1+ WARP: Safer Internet v6.37 [Xtra Mod] [Lite]
Requirements: 5.0+
Overview: 1.1.1.1 w/ WARP makes your Internet more private and safer. No one should be able to snoop on what you do on the Internet. We’ve created 1.1.1.1 so that you can connect to the Internet securely anytime, anywhere.
1.1.1.1 w/ WARP – the free app that makes your Internet more private – A better way to connect
1.1.1.1 with WARP replaces the connection between your phone and the Internet with a modern, optimized, protocol.
Greater privacy
1.1.1.1 with WARP prevents anyone from snooping on you by encrypting more of the traffic leaving your phone. We believe privacy is a right. We won't sell your data.
Better security
1.1.1.1 with WARP protects your phone from security threats like malware, phishing, crypto mining and other security threats. Enable 1.1.1.1 for Families option from the DNS settings inside the app.
Easy to use
One-touch setup to make your Internet more safe and private. Install it today, get a more private Internet, it’s that simple.
The only way to get WARP+
We test thousands of paths over the Internet every second to find which have the best performance. Skip right past Internet traffic jams using the same technology that we use to make thousands of websites 30% faster (on average).
Subscription Information for WARP+
• 1.1.1.1 with WARP is free, but WARP+ is a paid feature which can be enabled at any time.
• Subscribe on a monthly basis to receive unlimited WARP+ data for the duration of the subscription.
• Your subscription will automatically renew for the same package length at the same price until you cancel in settings in the Google Play Store at least 24 hours prior to the end of the current period.
• Any unused portion of a free trial period and/or WARP+ data transfer credits, if offered, will be forfeited when you purchase a subscription, where applicable.
◉ PREMIUM/Unlimited feature Unlocked (Unlimited + ZeroTrust)
◉ DEBUG Codes REMOVED (including source tags)
◉ LOGGING Codes & Some Classes REMOVED ★
◉ Network Logging Interceptor REMOVED ★★
◉ Some Kotlin Invocations REMOVED
◉ Apk Root Path Completely CLEANED ★
◉ Location + Zendesk + GOOGLE + Unwanted - Permissions + Receivers + Providers + Services + Activities REMOVED - Cleaned Manifest ★★
◉ GOOGLE Analytics & Crashlytics Disabled ★
◉ Firebase Auth, InternalApi & Ktx REMOVED ★
◉ GOOGLE Billing DISABLED (MF+Dex)
◉ Google Play Core including AppUpdate & Common REMOVED (except installation stuffs) ★★
◉ Other many Useless GOOGLE Classes REMOVED
◉ Zendesk Disabled & some Classes REMOVED ★
◉ No Active TRACKERS/Analytics and ADS Remains ★★
◉ Trash Classes including R and BuildClasses REMOVED
◉ No Credit Dialog Added at App Startup - a little bit faster Opening (rather at settings)
◉ Split APK Repacking Files REMOVED
◉ CLEANED + OPTIMIZED + ZIPALIGNED Package
◉ Watch & LDPI + Drawable Cleaned + Duplicate Graphics REMOVED
◉ Much CLEANED + OPTIMIZED Graphics
◉ No Ultra Compression Applied
◉ Overall Package Size Reduced Heavily (Xapk size is 237 MB / Converted Apk Size is 920 MB :shock: but my modded apk size is 117 MB) ★★
◉ Tried to Unitied with GOOGLE - AOSP Compatible (No GOOGLE) ★★
◉ Auto Update DISABLED (Update check Bypassed)
◉ CPUS: ARMv7, ARMv8
◉ LANGUAGE: English & Russian
MUCH MORE (but no need to Mention)
☢️ @RAIYANMODS ☢️
Lite:
◉ Based on above Xtra Mod
◉ Ultra Compression Applied
◉ Armv7 & Armv8 Splitted
◉ Whole/Combined Package Size was 117 MB
Now,
- Armv7 Size is 57 MB ★★
- Armv8 Size is 60 MB ★★
How to enable Zero Trust in 1.1.1.1 VPN?
1. Go to Settings
2. Press on Advanced
3. Go to Diagnostics
4. Scroll down to Client Configuration
5. Copy the ID
6. Go back to Advanced -> Connection options
7. Press on DNS settings
8. Press on Gateway DoH Subdomain
9. Paste "Client Configuration ID" into it and Apply
10. Zero Trust VPN is enabled
- Adds support for Android 14
- Active tunnel protocol is displayed; users can now switch between the WireGuard and MASQUE protocol
- Deprecated referral reception; users are notified if they have not registered with the WARP client
- All API and DNS traffic is now FIPS-compliant
- Fixed a crash related to Broadcast Receivers on Huawei devices
This app has credit advertisements
Xtra Mod:
https://www.up-4ever.net/c5zg1zvq8kur
