Requirements: 7.0+
Overview: THE WORLD'S MOST ADVANCED AD BLOCKER!
AdGuard is the best way to get rid of intrusive ads and online tracking, and to protect your device from malware.
Make your web surfing faster, safer and more comfortable with AdGuard!
AdGuard is a unique no root ad blocker for Android that removes ads in apps and browsers, protects your privacy, and helps you manage your apps
Easy to set up and get going, but powerful and highly customizable — it has everything you'll ever need from an Android adblock tool, and it works both on rooted and unrooted devices.
Why choose AdGuard?
Blocks ads everywhere
Block throughout the whole system. This includes video ads and ads in your favorite apps, browsers, games, and on any website you can imagine. Dozens of ad filters are available to you and are updated on a regular basis, guaranteeing the best filtering quality.
Cares about your privacy
We value the privacy of your personal data above anything else. With AdGuard, you will be safe from online trackers and analytics systems that lurk on the web trying to steal your sensitive information.
Saves your traffic
More ads blocked means fewer ads loaded. Fewer ads loaded means more traffic saved. Simple math by AdGuard! Download the apk file, install the app and spend your traffic on things you like instead of wasting it on voracious ads.
You stay in control
It is your device, after all, and you decide what gets filtered and what doesn’t. A wide range of settings — from basic to 'pro' — as well as an Apps Management tool will help you customize the filtering to your liking.
Try AdGuard ad blocker for Android apps for free and feel the difference! Once you go with our app on your tablet or mobile phone, you'll never want to go back.
Today’s version is exactly what we love: it introduces a fresh feature we couldn’t wait to see on the app. And it’s no small release – we’re introducing an in-app privacy browser to the app! Let’s take a closer look at what’s new.
AdGuard v4.7 is the last version that supports Android 7 and 8. Starting with the next release, we will only offer support for Android 9 or higher.
A private browser, because there’s no such thing as too much privacy
Keeping privacy in mind while browsing has become an essential part of many users’ everyday life. We want our app to be part of that routine, and that’s why we’re rolling out the AdGuard private browser, bringing an extra layer of privacy to your daily web experience.
So, what’s so cool about this browser?
Ad and tracker blocking (of course!)
Easy history deletion with a visible, accessible button. Also, your browser history is automatically cleared when you close the browser
To explore this new feature, tap Try our private browser on the app's home screen. You can also access the browser through the Protection tab, where you can set a default search engine and even create a browser widget.
Just a heads-up: our private browser is still in the early stages of development and has a few limitations, like the inability to handle multiple sessions at once. In the future, we’ll offer a more comprehensive browsing experience, but for now, we suggest using it as a supplement to your usual browser’s Incognito Mode, rather than a replacement. Sounds good?
Changelog
Improvements
Incorrect translation of Fanboy's Annoyance List description;
Fixes
“Allow app usage access” popup does not disappear after enabling the corresponding switch in the system settings on Android 9;
Almost all apps are no longer logged as filtered;
Cursor barely visible at search bars in the Dark theme;
Enabling/disabling the switch “Trusted filter” doesn’t make protection restart;
Incorrect error message when trying to send a report with an invalid email on the Report a bug screen;
Magenta color of AdGuard notification if protection is paused;
Routing for problem apps in groups is enabled when you turn on this option for problem-free apps;
TCP keepalive for outgoing sockets screen doesn't scroll;
The user rules are positioned in the middle of the editor;
Translations are missing for Annoyances blocking notice;
The app crashes when Android WebView is unloaded;
Other
it.labfabrici.hub does not work when protection is working.
Mod Info:
Premium / Paid features unlocked;
Disabled / Removed unwanted Permissions + Receivers + Providers + Services;
Optimized and zipaligned graphics and cleaned resources for fast load;
Debug code removed;
Remove default .source tags name of the corresponding java files;
Analytics disabled;
Native Sentry code removed and disabled;
Disabled startup screen;
No patched watermarks;
Languages: Full Multi Languages;
CPUs: armeabi-v7a, arm64-v8a, x86, x86_x64;
Screen DPIs: 120dpi, 160dpi, 240dpi, 320dpi, 480dpi, 640dpi;
Original package signature changed;
Release by Balatan.
All-in-One Universal Mod:
https://frdl.to/xnd1b9rmz9f2
