VovSoft OCR Reader 24 Mb
Optical Character Recognition (OCR) is the electronic conversion of images of typed, handwritten or printed text into machine-encoded text, whether from a scanned document or a photo of a document.
Digitize scanned documents
Vovsoft OCR Reader is a small and lightweight OCR tool that can easily digitize image files and scanned documents on your laptop or desktop computer. This application utilizes Tesseract OCR engine, which supports more than 100 languages. In order to increase accuracy, it uses a neural network (LSTM) based OCR engine which is focused on line recognition, but also can recognize character patterns.
Extract text from images software
This image to text converter program allows you to extract text from PNG, JPEG, TIFF, WEBP and BMP image files using Optical Character Recognition. While there are many OCR tools available online, some prefer a dedicated desktop tool instead. The best part of the program is that the conversion is done completely offline. You are the only controller of your private data. No image file is sent to internet in any case.
This program is available both as installer and portable, that can be carried around and used on the go whenever needed. It features a simple interface with a minimal number of options. In other words, the GUI is meant to be uncomplicated to make usage as easy as possible.
Operating System:Windows 11, Windows 10, Windows 8/8.1, Windows 7, Windows Vista, Windows XP (32-bit & 64-bit)
https://fikper.com/jPqPMoBAG3/ejfoy.Vov ... 1.rar.html
