Able2Extract Professional 20.0.3 (x64) Multilingual Fast Links | 110.6 Mb
Able2Extract is the only PDF converter on the market that effectively boosts your PDF productivity on Windows. Convert PDF to Word, Excel, PowerPoint,
Features:
Cover all aspects of your PDF work at office and home with Able2Extract PRO:
Convert PDF files to all major formats including Excel, Word, CAD, PowerPoint...
Create PDF files from WebP images and vice versa.
Extract scanned PDF content using OCR with multi-language support.Improved
Extract all images from PDF as individual image files.
Edit PDF content, manipulate pages and PDF forms in real time.
Compare two PDF files side-by-side and highlight the differences.
Process hundreds of files in one go with batch conversion and batch creation.
Bulletproof your PDFs with passwords and add electronic and digital signatures.
Easy-to-use UI and Dark theme support for even more efficient workflows.
Fully compatible with Windows 11 and Microsoft Office 2021.
PDF to PowerPoint
Transfer visual content and business PDF presentations into editable PowerPoint slides. Edit and polish off your keynote content in Microsoft PowerPoint.
PDF to AutoCAD
Recover CAD drawings by converting PDF to DWG and DXF, while retaining vector graphics and text. You can freely work with the conversion output in other CAD applications.
PDF to Images
Convert PDF to JPG, BMP, PNG, TIFF, GIF, and WebP images. Apply image specific settings for your conversion such as DPI, image resolution, GIF animation speed, JPEG quality, and more.
Extract All Images
Instantly extract all images within your PDF file as individual image files without any quality loss. All images are stored in a designated folder and ready for use in other programs.
PDF to HTML
Convert your PDF content into HTML you can easily upload and share online with others. Single and batch output support with replicated formatting and layout.
PDF to
Convert PDF to
DF to Open Source Formats
Convert PDF to formats native to OpenOffice and LibreOffice: Writer (ODT), Calc (ODS), and Impress (ODP).
System Requirements
OS: Windows 11, 10, 8.1, 8, 7, Windows Server 2022, 2019, 2016, 2012 R2, 2012, 2008 R2
RAM: 512+ MB of free memory available for the software
Hard Drive Space: 200 MB of disk space for the program components
Monitor: 1366 (Width) x 768 (Height) screen resolution (higher resolution screen required if OS scaling is more than 100%)
https://fikper.com/DVhY92SdIG/z3o99.Abl ... l.rar.html
