ADB AppControl 1.8.6 Extended Multilingual
ADB AppControl 1.8.6 Extended Multilingual | 7.2 Mb
ADB AppControl - a new and handy desktop program, that will allow you to easily manage applications on your android device. You can disable unwanted pre-installed system apps and bloatware, or install new ones using a modern graphical interface. The program includes many useful tools and tweaks which allow you to get the better experience with your device. This is exactly the tool that you will use for many years - after trying ADB AppControl you will see that working with applications via adb has never been so easy.
* Due to Android restrictions, system applications cannot be permanently deleted and their apk files will remain on the system. There is no way to remove them without root privileges. These applications will not start and run - they are not installed for the operating system.
Forget the command line!
You have a completely list with all installed applications and you no longer need root rights to manage them! Uninstall, disable, and install apps. Manage permissions and configure your device the way you want it.
Bloatware cleanup
The ADB AppControl's Debloat Wizard offers several levels of unwanted application cleanup for beginners and advanced users. This will help improve the autonomy and performance of your Android device as well as secure your personal data.
More features
Change screen resolution, hide annoying icons in the status bar, take screenshots and remotely control your device. And if you haven't already forgotten about the command line, there's a handy console for you. ADB AppControl has many features that you will love!
Want even more features?
Become a project sponsor and get access to the Extended Version with new cool features. Bloatware cleanup, interface theme selection, app batch installation and more now and in future updates!
System Requirements: Windows 7, 8, 8.1, 10, 11 and .NET Framework 4.6 or higher.
https://icerbox.com/lWBAqjen/ADBAppControl-1.8.6.rar
Return to “Computer Software's Update”
