Macrorit Data Wiper 8.1.0 Multilingual Fast Links | 10.7 Mb
One-stop Toolkit for Secure Erasing Data, Partitions and Disks. Completely wipe system/boot partition. Many program files are stored in system disk drive by default. If you or your organization want to permanently wipe disk drive to prevent your data from unauthorized using, this feature is necessary.
Features:
- New! Wipe unallocated/free space with fast wiping algorithm.
- New! Built in brand-new Macrorit algorithm for fast wipe NTFS partition.
- Completely wipe disk or a separate partition, USB drive, external hard drive, etc.
- Irreversibly erase sensitive data easily and quickly.
- System or boot partition can be wiped directly without limitation.
- Allows commercial use and provides charged service to your customers.
- Full newest Windows 8.1 and Windows 8/7/XP/Vista, Server 2003/2008/2012 and Home Server 2011, Windows SBS 2003/2008/2011/2012 (both 32 & 64 bit) support.
- Completely wipe system/boot partition. Many program files are stored in system disk drive by default. If you or your organization want to permanently wipe disk drive to prevent your data from unauthorized using, this feature is necessary.
- Commercial use means IT Pros, technical service providers, or other organizations have authority to provide charged technical services to help diverse clients.
- Periodic friendly notifications. Rest assured that you or your organization will always know about the latest updates and improvements to Macrorit perpetual software.
Features at a Glance!
- New! Wipe unallocated/free space with fast and secure wiping algorithm.
- New! Includes both portable and standard install package. Small size with faster process speed and less CPU resouce.
- New! Upgraded to the famous Windows 8 / Office 2013 user interface.
- New! Bugs fixed in previous version.
- Quickly and efficiently sanitize the hard disks and wipe/erase exactly what you need.
- Wipe hard disks or separate partitions (system, boot partitions; primary, extended or logical).
- 6 wiping methods irreversibly destroy all on-disk data.
- It rarely occupies system resource.
- Extremely easy to manage and understand Windows style.
- Support for the latest HDD standards (Advanced Format Drive), 2TB+ and non-512B sector size drives.
- Support large IDE, SCSI, SATA and newGPT/uEFI-formatted hard disks, USB 1.0, USB 2.0, USB 3.0 flash memory drives.
- Common FAT16/32, NTFS file systems are supported.
- Well compatible with latest Windows 8.1 and Windows 8/7/XP/Vista, Server 2003/2008/2012 and Home Server 2011, Windows SBS 2003/2008/2011/2012 (both 32 & 64 bit)
- Support GPT disk up to 4TB.
- Support all hardware RAID wipe operation, such as RAID 0, 1, 5, 10, etc.
- Wipe virtual hard drive in VMware, Virtual Box and Virtual PC.
Operating System:Windows Server 2022/2019/2016/2012/2008/2003 and Windows 11, 10, 8, 7, Vista and XP (Both 32& 64 bit)
https://fikper.com/3nnZ335ats/wbyqh.Mac ... l.rar.html
