v2.12- last updated: 30/10/2024
The plugin was meant to be dead as was going to write a new version. Been busy so not even started that yet.
I don't think I have updated anything other than a slight code clean up and user-agent update
Also included the new bevy-epg.txt file in the etc/enigma2/jediepgxtream folder if you want to copy any of them across to your epglist.txt file
Just tidying up my local files
enigma2-plugin-extensions-jediepgxtream_2.12_20241030_all.ipk
https://uploadrar.com/x6qucfa0la1y
enigma2-plugin-extensions-jediepgxtream_2.12_20241030_all.deb
https://uploadrar.com/blletyotjiez
