Zero Backup vu+zero openspa 8.4.002
This Section Using About Download Software Vu Solo Receivers .....
abou01
Has thanked: 8 times
Been thanked: 7 times
Algeria
Post by abou01 »
openspa 8.4.002 --- py3.12.4 -- 30 / 10 / 2024
Image openspa 8.4.002 .py3.12.4
Device VU+ZERO HD
Works excellently
Tested on external
On the outside due to the latest advanced updates
The big ones on weak devices with small memory do not tolerate the new updates, you should use the hard disk or USB and this backup all the modern plugins
And it works excellently and contains the ipaudiopro plugin developed by the dear Zakaria, thank you
And the transmission plugin developed by the dear Radwan, thank you
And on it the MultiStalkerPro plugin for translating movies into Arabic and thanks to Professor Zakaria, the developer of these plugins
And the Subsupport plugin for translating movies into Arabic works excellently
And it has 2 distinctive skins skins-xDreamy_3.9.0 / skins-aglare-fhd-pli_4.5
And thanks to the designer brothers inspiron80 / MNasr
And thanks to the five professors who developed the magical panel
And it works on the French TNT, it works on the EUTELSAT 5 satellite.
And on the Astra 19 satellite with high and stable efficiency
And Thanks to Professor Hassan for the excellent Alaymo
Ncam_15.0.1 / fairman
oscamicamnew_11847-ICAMEMU-Kitte888
oscam-emu-levi45_11847-802
cccam -2.3.9
and an internal image openbh and works with multiboot
and works on it Spanish terrestrial channels on
Eahepsat 30w and American channels on Hotelsat 9E. And German channels on Astra 19E
and there are 2 plugins for servers for free and they work with great efficiency and they have important plugins
and whoever wants the beacons can use an external hard disk or USB key
**ftp**
user/root
Pass/root
https://www.mediafire.com/file/5rvk4lzt ... b.zip/file
Return to “Vu Solo Receivers”
